Pinball Repair
noice87
Glenn Heights, Texas
Finally got my Game Plan Sharp Shotter home and the lights come on but nothing else. What are the rates for Pinball repair? I don't want it completly shopped out just working.
Thanks Steven
No idea how to do terst mode. On one of the boards a red light flickered a bit but latter was not on. When I had it at the storage unit one of the boards was in the bottom of the cabinet. I hooked it back up. Will get some pics this comming week.
Thanks Steven
when you turn it on, you should hear a boom followed by a rattlesnake. the big board in the center of the head is the MPU. that should blink 6 times if it is okay. to enter test mode, just press the service switch. the first nine or so test are audit, but you will then have a display test (cycles through all the #'s) then the solenoid test followed by switch test and light tests.
Thanks for the links. I had seen the Gameplanpinball one but didn't look over it much. My MP2 board has no battery and I see no acid damage. Also all 5 fuses are good. Will mess with it this weekend.
