Rattanee
Hey folks,
I haven't been around for a while due to personal reasons, and I've decided I'm getting out of the hobby. Thusly I'd like to sell off a rather large inventory of parts.
PRICES are in AUD and are PER PIECE unless otherwise noted!
Feel free to make offers, everythign must go!
List updated:
ELECTRONICS:
MPU boards (All MPU boards come without eproms, however I can program eproms of your choice for $3 a chip):
Sound boards (Again they come without eproms, can program eproms of your choice for $3 a chip):
Bally first version sound board, missing some chips. $10
Power supplies:
Williams Sys11 PSU - Have three, all working fine with no burnt connectors, one is missing a single connector header (needed to snag it for a quick repair) ships without fuses - 20 AUD/board, $50 for all three
Lamp drivers:
Displays:
Misc. Electronics:
Data East PPB . Missing some connectors and TIP36c transistors 5 AUD
Data East rumble motor pcb 5 AUD
Williams under PF driver pcb, I think it's a Whirlwind spinner driver pcb 5 AUD
ORIGINAL PROTOTYPE F-14 tomcat and High Speed roms, only for the avid collector 20 AUD for both
Under plafyield lamp boards, sockets, lighting:
Set for Bally Goldball 15 AUD
Set for Data East Royal Rumble 15 AUD (might not be complete)
Set for Whirlwind 10 AUD (Probably not complete)
PROTOTYPE RED single $555 lampboard, original williams part, have 3, $10 takes all three.
20pcs Data East under pf #44 bulb sockets, both long and short stands $5
17pcs Data East under pf #89 blub sockets $8
12pcs WMS #89 bulb sockets, under and above playfield $5
Playfield switches, actuators, misc stuff etc.:
xxpcs Data East all rollover switches from Royal Rumble (will have to check exact number) $10
Zaccaria playfield switch base, transparent red 1pc 1 AUD
11pcs Data East under pf cabling stand $5
Microswitches, actuators, lamp sockets for pretty much all generations of pins, just ask. I'm letting these go very cheap so I would prefer to sell them in lots. There are both new and used ones. Let me know what you need and we'll figure out a good deal.
PLASTIC PARTS:
Plastics, plastic sets, bumper caps:
Whirlwind thin, long teal plastic next to shooter lane $1
Transparent ball-guard plastic for left hand shot on Bride of Pin-Bot $2
Simpsons speaker grille plastic 5 AUD
Iron Maiden (Not complete) 20 AUD
Goldball (Complete) 20 AUD
Pin-bot (Not complete) 10 AUD
Flight 2000 (Not complete) PENDING
Firepower II (Not complete?) 10 AUD
Bally Embryon bumper cap set - $15
Bally Silverball bumper caps, one smaller "50" and one "gandalf head" cap, needs cleaning, but good shape. $10
1000 points when lit bumper caps, Powerplay in good shape, 3pcs $15
Flight 2000 bumper caps, 2pcs $10
Ramps:
Pin-bot blue ramp - not flawless, but perfectly usable, looks good in game, has a small molten bit near one of the switches, does not affect play - 5 AUD
Whirlwind main ramps, Pretty beat up, but the skyway toll caps, switches are all there, 5 AUD for the pair (Both are beat at the entrances, left ramp is usable with protectors but needs a crack glued.)
Whirlwind wireform ramp with the plastic intact 5 AUD
Misc plastic parts:
Whirlwind cellar signs, flawless 8 AUD
Williams F-14 Tomcat Prototype/early production transparent domes, red has some scratches but good, white is a bit yellowed but not broken yet, blue has one bit missing from the rim, but it's usable and not seen when mounted. PENDING
Zaccaria 'shield' flipper, transparent red, no shaft, no cap, 1pc 3 AUD
Stern scoop/saucer switch actuator, red plastic 5 AUD
Posts, lane guides:
Williams red star-post, shorter style, 55 pcs
Williams white star-post for two rubber rings 16 pcs
Williams blue star-post, taller type 15 pcs
Williams white star-post, shorter style, 6 pcs
Williams blue star-post, shorter type 2 pcs
Ring-post, red, taller type 42pcs
Ring-post, red, shorter type 12pcs
Ring-post, blue, tall 3pcs
Stern red post ("diamond" pattern), taller type 16pcs
Stern red post ("diamond" pattern), shorter type 12pcs
Red post "smooth" short, 2pcs
Red post "smooth" tall, non-transparent 1pc
Asking 50 cents a post, they're used, but all the chipped ones have been tossed, they just need to be cleaned up.
Blue lane guide, 3.8cm between holes 2pcs
Teal, non transp. lane guide, 3,8cm between holes 1pc
White lane guide(slightly yellowed), non-transp, 3.8cm, single-sided 1pc
Red lane guide 5.3cm single-sided 1pc
DE - top lane guides, thin, red, (see royal rumble) 3pcs
Asking 1 aud per lane guide.
MISC PLAYFIELD PARTS:
Apron - Data East Royal Rumble $20
Apron - Gottlieb TX Sector $5
Apron - Bally Bobby Orr's Power Play $15
Apron - Stern Flight 2000 $10
Apron - Williams Judge Dredd $15
Apron - Bally Beat the Clock $15
Shooter rod coverplates, williams sys11, older bally, stern $2 a piece
Stern - spinners (one with a bowling pic, the other with a star on each side) 2pcs PENDING
MECHANICS:
Cabinet mechs:
WMS - F-14 Tomcat beacon motor+reflectors, no belts 30 AUD
Complete mechs:
DE - Ballthrough release mech 15 AUD
DE - Mini-playfield lock kickout mech for Royal Rumble 15 AUD
DE - Slingshot earlier version, plastic base, complete 2pcs 24 AUD
DE - Bumper (plastic base) complete (23-800 coil), no bumper cap, one base chipped in one corner 3pcs 35 AUD (30 for the cracked)
WMS - Knocker set (with plate and plunger) 2pcs 20 AUD
WMS - Ballthrough kicker for old style ballthrough, missing return spring 10 AUD
WMS - Firepower II switched gate 5 AUD
GTB - System 80b knocker 2pcs 15 AUD
Bally - Red popup post (between flippers, Bobby Orr and the like) 15 AUD
Bally - Saucer kickout mech complete 2pcs 20 AUD
Bally - Bumper, (plastic base) complete, working, but needs to be cleaned 6pcs (3 have no bumper body) 20 AUD
Bally - "linear" type slingshot mech, complete 2pcs 20 AUD
Bally - kickback mech complete 1pc 15 AUD
Stern - Diverter set (mechanics, coil, diverter plate incl, from Iron Maiden) 3pcs 15 AUD
Stern - Flight 2000 ball lock mech, complete 20 AUD
Stern - Bumper(plastic base), 26-1200 coil, no bumper rings, no caps, base chipped in two corners 2pcs 20 AUD
Mechs w/out coils (No stop plates either):
DE - Slingshot from Rev3 era, metal assy, switches included, no coil 2pcs 25 AUD
DE - Diverter set (Royal Rumble), baseplate, actuator, diverter, no coil 2pcs 20 AUD
Bally - saucer mech, no coil 10 AUD
Stern - saucer/scoop kicker mechanic, no coil 10 AUD
Mech components:
DE - Flipper baseplate 4pcs (deger) 10 AUD
DE - VUK baseplate 10 AUD
DE - Knocker baseplate 5 AUD
WMS - Droptarget bank, 3 targets with Whirlwind decals, pcb (Coil, plunger, reset plate not incl. missing optos) 15 AUD
WMS - Droptarget single, whirlwind yellow decal, pcb (coil, plunger, reset plate not incl. missing optos) 10 AUD
WMS - RFM ball lock/VUK baseplate, flawless 25 AUD
WMS - RFM - center ramp lift baseplate 10 AUD
WMS - flipper baseplate RIGHT 3 pcs 10 AUD
WMS - RFM right eject hole baseplate, worn 5 AUD
WMS - Slingshot/general purpose bracket/baseplate (While they're available, buyer chooses, 4 NOS, 2 copper coloured, other 4 used, all in near perfect condition aside from storage dirt)10pcs 9 AUD
WMS - Bumper baseplate (4 pcs NOS) 8 pcs 5 AUD
WMS - knocker/kicker baseplate 2pcs 5 AUD
WMS - scoop/ballthrough kicker armature and arm 2pcs 7 AUD
Bally - Plastic bumper base /w scoop switch and upper half of metal bracket 3pcs 10 AUD
Bally - Flipper baseplate pair ("linear" type) 5 AUD
GTB (?) - Bumper base (metal) 5pcs 5 AUD
Bally - Knocker/kicker baseplate 2pcs 5 AUD
Stern - Flipper baseplate pair 5 AUD
Stern(?) - Bumper baseplate (metal) 5 pcs 5 AUD
Stern - Slingshot bracket/baseplate 2pcs 5 AUD
Plungers:
WMS - RFM ramp-lift plunger 10 AUD
WMS - RFM VUK plunger (no scoop) 7 AUD
WMS - kickback-style plunger 8.8cm end-to-end
WMS - kickback-style plunger 7.2cm end-to-end
WMS - kickback-style plunger 6.6cm end-to-end
WMS - Droptarget plunger/reset plate (3 targets)
WMS - Droptarget plunger/reset plate (single)
WMS - bumper plunger 2 AUD
DE - NOS VUK plungers, spring-scoop type, bare plunger 2pcs 10 AUD
Bally - kickback plunger 2pcs
Bally - bumper plunger
Asking 5 AUD each unless otherwise indicated above.
Bare coils:
WMS - AE 23-800 8pcs
WMS - SA - 3 - 23 - 900DC 1pc
WMS - SA - 3 - 23 - 850DC 2pcs
WMS - 24-900 1pc
WMS - G23-750DC 1pc
WMS - AE 26-1200
WMS - A-14418
WMS - FL11722/50V
WMS - SG23-850DC
WMS - AE1-25-1000 (quick connect for P2k) 1pc
Bally - AN/AR-26-1200 7pcs
Bally - 34-3600 1pc
Bally - 26-500/34-4500 (Flipper coil) 1pc
Stern - j-28-2300 1pc
Stern - j-26-1500 1pc
Stern - b-27-2300 1pc
DE - 27-1500
DE - 23-800 2pcs
Asking 6 AUD a coil.
More to come
IRON MAIDEN playfield - The PF is a very good candidate for restauration, has two problems, one small wearspot on the upper pf, and the playfield prop-rod wore through the playfield, which needs to be repaired before a clearcoat. Otherwise very nice condition, mylar has already been removed. asking 200 AUD
Have lots of bits and pieces aside from what's listed. I'll gladly make mutually good deals for larger purchases, will combine shipping if necessary of course. Toss me a PM if you're interested, or write an email to 4vatera at gmail dot com.
List updated:
ELECTRONICS:
Power supplies:
Lamp drivers:
Displays:
Misc. Electronics:
PLASTIC PARTS:
Ramps:
Misc plastic parts:
Posts, lane guides:
MECHANICS:
Cabinet mechs:
Complete mechs:
Mech components:
Plungers:
Bare coils:
WMS - 24-900 1pc
WMS - G23-750DC 1pc
WMS - AE 26-1200
WMS - A-14418
WMS - FL11722/50V
WMS - SG23-850DC
Bally - 34-3600 1pc
DE - 27-1500
DE - 23-800 2pcs
More to come
