Pinball machine help on the solenoids
TiffanyArcade
Las Vegas, Nevada
Hey I have a few pinball machines and can't seem to fix the solenoids to not stick when they click on. Should I spray something on it is it corroded? Should I just clean the contacts? Kind of new to the whole pinball restore so :)
Ken gave you a great guide to follow. Solenoids sticking can be a few different things.
A.) Every solenoid has what's called a coil sleeve which is simply a removable plastic tube/shaft. These become worn with time. It's best to replace them as the wear will drag the plunger causing slow response. Sometime you can simply remove them, cleen them up and they'll be fine. Sometimes adding grphite dust will help also.
B.) If the solenoid engages when power is applied this is usually indicative of a blown TIP transistor, pre driver transistor and/or diode. Depends on what era of pin we're talking about.
You should NEVER NEVER NEVER NEVER do this. Lubrication has no business near a solenoid. If a solenoid sticks....something is broke, worn, loose, needs to be replaced/repaired.
Not too mention....depending on the game/era/solenoid....and lubrication used.....you could catch your machine on fire.
Edward
