xrayrox
Having some problems with my pin reset motor on my United Astro shuffle bowler. It was working well but intermittently for the past year or so all the pins would reset and freak out randomly, usually not when resetting. So tonight the kids are playing and the pins will not reset and the pins were freaking out a lot worse than normal. I checked the pin reset motor and the actuator in the motor doesn't stay engaged long enough for the pins to reset and the motor keeps running trying to reset them. I understand there is a spring at the end of the actuator to disengage it from the gears but it is missing. If I manually keep it engaged until the pins reset it will disengage with no problem, so I don't think the spring is the problem. Any suggestions? thanks in advance
