Keep in mind I'm new to pins here....
I got this Pin Bot a while back and couldn't do much diagnostics because the displays were bad. I finally bought a set of Pinscore displays so now I can actually get feedback on what is wrong. Yay.
When I turn the game on, it powers up fine and goes through the regular startup sequence but it won't coin up at all. If I cycle through the setup I can see the various settings but I'm not able to change them. Pressing the start button has no effect and won't make a change at all.
If I run the switch tests and check them individually, when I press the start button it pops up and calls it a "Right Lane Change" switch on the display. What's that all about? That's also what it says when I press the right flipper button.
Also, when I activate the left-hand coin switch it says "Left outlane" and when I activate the right-hand coin switch it says "Right return".
This doesn't seem right to me. What's going on you think?
