Could t get the camcorder to get a good recording of the Monitor. So I went ahead and took out the Monitor chassis and it doesn't look like the caps were ever replaced. It also has an orange pancake like transistor or what not that I believe goes to the degauser if I said that right. It's all cracked but test good. Fuse 501 was good, the pins on the board were fine for some reason someone put solder on them but when I took it off there was nothing wrong there. So one of the fingers is curling up so I will take some super glue and glue it back down. So far I can't see the proble. Just wondering will caps cause a black screen ? The Monitor has really bad burn-in. I never noticed it before but I guess it was because of the anti glare plastic or tinted black screen that lays over it. Is there any way to fix that as well ?
burn-in is not fixable because its the phosphor that is missing off the inside of the tube. post a picture of your issues in question so you can get proper resolutions and don't cause more damage when fixing.
