I'm working on installing LEDs throughout my Batman Forever. I've got the backbox and playfield inserts changed as well as almost all the flashers. I still have most of the GI left and I'm waiting to do that until I get a ring kit so I can kill two birds with one stone when I've got parts removed from the playfield.
I purchased frosted warm white bulbs (not superbright) for the backbox and the bulk of the playfield GI. I picked a few spots for the playfield GI where I'm going to put in colored bulbs. I also installed colored bulbs under all the playfield inserts. This by far is the best thing to do, the inserts look awesome.
After installing the LEDs in the backbox, it looked spotty. Even with the frosted lens, LEDs still are pretty bright when viewed head on as is the case in the backbox. Below you can see what I'm talking about. It is especially noticeable on Chase's forehead and hair, Batman's right shoulder below Chase's chest, Riddler's forehead and shirt, the lower left part of the moon above Batman, and around Forever in the bat symbol.
My solution, a dab of black paint on all the LEDs to cut the direct spot effect. You now get more diffuse lighting from the perimeter of the LED. The picture below was shot at the same f-stop and aperture as the previous picture. You can see the spotlights are toned down quite a bit. I think you can easily see the difference in the pictures, but it is definitely a noticeable difference in person.
Note: A few of the LEDs in the first "before" picture already have the black paint on them. As I was swapping them out for a direct comparison and the photos, I didn't have enough unpainted LEDs to swap them all out. But I did put unpainted LEDs in the locations that show the worst effect. So needless to say, if all the LEDs were unpainted it would look worse than what you see in the first picture.
If I'm being totally honest, I like the look of the backbox better with the incandescent #44 bulbs. It is warmer and I think it looks a little better with the faces. Even warm white LEDs are pretty white compared to an incandescent bulb. But I'm not going back, I'm leaving the LEDs in place.
I'm also putting a dot of paint on some of the LEDs for the playfield GI where they are under plastic and appear spotty.
