There looks to be a key there but I can't get to it. I've already loosened things on the other side (the gear, removed the e clip, etc) but nothing so far. I've got a couple of ideas at least, but wanted to check around in case anyone knew for sure.Take a pic from behind. I had 2 cabarets, but I don't think I messed with the controls on them.
I think the ur has a slot in the steering shaft that holds an alignment key. Can't imagine they would change things up that much.
Maybe try leaving that side alone and see if you can free up the other side and slide the shaft out to free up those gears.
EDIT: Got it. Sprayed a bit of grease in there and went to prying at it and it finally came loose with a bit of effort.
