Bullwinkle
OK..this is what's happening. I've completely rebuilt the power supply board including all caps, diodes, pin headers, the entire hv section, the two big diodes and the filtercap..so everything with the exception of the bottlecap on the big heat sink. I've also replaced the the female connector at J6 with a crimp style.
On both the mpu and driver board, I've replaced both female and male interconnects and all other pin headers. On the mpu, I've replaced the female connector that supplies the +5vdc and +12vdc with a crimp style connector and I've replaced all IC sockets with machine pin sockets.
PSB voltages:
12volt pin on J6 is 13.428
5volt pins on J6 are 5.073
+90volt pin on J5 is 89.47
-90volt pin on J5 is -93.35
+5 on J5 is at 5.073v
Lamps (+16 to 20volts) on J4 is 20.27
Sols (+28 to 38volts) on J3 is 39.42
MPU voltages:
TP1(+12v) is 11.46v
TP2(+5v) is 3.91v
TP3(+5v) is 3.95v
TP4(+5v) is 4.45v
TP7(+4.3v) is 4.78v (w/ power)
TP7(+3.9v) is 4.49v (w/o power)
TP8(+5v) is 4.84v
TP9(+5v) is 4.94v
D17, non banded side
w/power = 4.87v
w/o power = 4.87v
D17, banded side
w/power = 4.78v
w/o power = 4.51v
IC19 pin 22 (using pin 8 as ground) = 4.78v
IC1 pin 8 (without power) has no voltage.
I'm guessing my random resets are due to the lower +5vdc on the mpu. Is there a component that should be looked at that might cause the voltage for the +5 to drop at various points on the mpu?
thanks
-tom
UPDATE: The harness delivers 4.97v and 11.79v to the MPU at the connector... the values change a bit on the ps board when its under load, I'm assuming that's normal (please chime in if that's incorrect)... That being said, TP2 and TP3 are close to 3.9+v. Component on the board somewhere? I have another system 6 board that I'm working on resurrecting to see if I get different values. If anyone has any ideas, they are greatly appreciated.
PSB voltages:
MPU voltages:
TP1(+12v) is 11.46v
TP2(+5v) is 3.91v
TP3(+5v) is 3.95v
TP4(+5v) is 4.45v
TP8(+5v) is 4.84v
TP9(+5v) is 4.94v
w/power = 4.87v
w/o power = 4.87v
D17, banded side
w/power = 4.78v
w/o power = 4.51v
thanks
-tom
