Picked up a Double Dragon-
SavePointVG
North Carolina
This one has been left out in the rain and the mdf is crumbling away. Im putting it into a new cabinet but thought I would show off some of the weird things about it. The DD decal on the front, also the inside looks like it has pieces of another cab for support. Tube and chassis are in great shape, had to replace the power supply to get it on, the last picture shows what the game does when fired up. I havent had to do any board work at all on any of my machines so not really sure whats going on there- I did notice a rotten cap on the board.
(Pictures are big so one is shown, others are linked)
The inside supports
http://i.imgur.com/v6QGS.jpg
http://i.imgur.com/durv2.jpg
Serial from what it may have been in the past
http://i.imgur.com/s2heV.jpg
Screen after boot up
http://i.imgur.com/jz3rV.jpg
Board(other than dusty not really sure whats up)
http://i.imgur.com/2sEe4.jpg
looks like dare devil tagged your cab. I would say its someone did personally rather than any kind of kit. Looks like a dedicated cab. Too bad the cab is water damaged as dedicated DD is popular.
The inner wood piecs are common. damaged/no longer needed cabs are cut up at the factory and used for scrap wood. I am sure someone will be able to ID the scraps of wood.
Make sure you don't power it up with the 2 boards touching/shorting out. It should have spacers to keep them from touching. Try reseating the socketed roms and make sure its getting +5v at the board. Luckily there are tons of DD boards, so if its bad, you can find another.
