Ok. Into the parts bins they go. lolThe VDR's are also the same as the ones used on many color vector game boards. So you'll be better off saving those, if you ever build up a repro Major Havoc, Gravitar, or Quantum PCB someday.
Harris Al-Solder 500. It's actually intended for soldering aluminum but it works for other stuff too. I originally got it to solder the tabs together on LiPo batteries which are either steel or nickel and aluminum.
I love that blaster!
How well is it sealed? Does it leak media at all?
Nie work on that diode. That's how you do it. FYI, to test your work, when you reassemble everything, run the cage for 10 minutes. Power down, discharge the tube, then feel the diode with the back of your finger. If it's cool to the touch, you're good to go. If it's scorching hot, either the diode is bad, or one of your solder connections isn't solid.
Fascinating. I always thought there were multiple physical PN junctions in that long package. Wow
if you have full brightness and a clean beam i would not bother.More unrelated. Digging though my storage area and found this guy, friend gave it to me years ago, saw it when I moved. It it worth checking the tube with this thing? Manual is missing and I will need to make the universal adapter.
Seems to work, I'll have to run it though it's tests.
