Phoenix
newthing34
Donor 7 years: 2013, 2020-2025
San Jose, New Mexico
Hello
Can someone take a picture of the way the monitor is mounted & what are the small 3 brackets on the left side for.
Hello
Thank youView attachment 770689
i have a vision pro monitor in mine, which is a horizontal monitor mounted on its side in the cab for vertical tube orientation. the monitor frame has a timber base to which three brackets are attached. these line up with the brackets on the side and are the mounting points for the monitor, rather than a vertical monitor sitting on the shelf. pics below. in fact mine has only one bolt in the middle bracket holding the monitor in place! i need to add the missing two bolts so all brackets are securely joined and hold the monitor securely.;)
If you want an overall pic of the monitor from the rear, let me know.
Also wondering if you could take a pic of the label on the top left below the marquee, and measure the size of the label ? - not sure if i have that on mine - might have to go and check.
Mr. Andy you rock
Yes A picture overall from the front & the back would be great
I think this is the label you are talking about
ps the monitor brackets sit on TOP of the cab side brackets - mine are underneath - have to change that when i fit the other bolts, otherwise installing/removing the monitor is going to be awkward.
ok will take the front/back pics for you.
