Phoenix switcher question
_jmfr
St Louis, Missouri
Im tryin to get my phoenix to work. Im putting in a known working switcher to see if i can get the pcb to work, but something has stumped me. There is 2 wires connected to a spot on the switcher labeled "OV". What does this mean? The new switcher I have doesnt have a spot labeled OV. What should I do?
OV as in zero volts? Let's see a pic of the old switcher, but it may just be ground....
Im at my college APT and dont have a cam. I traced the wires, and the first one is a ground on the edge connector, and the other one runs to the coin door. Both wires are grey, and they connect to the switcher at 2 different spots. Im pretty sure they're both grounds but not 100 percent on that
A modern switcher only has so many hook-up points....
AC/AC/Ground/+5VDC/+12VDC/-5VDC/Earth ground (also can be called field ground).
Process of elimination...What are you missing?
Edward
