Is there someone that works on the monitor chassis for Centuri's Phoenix, arcade game?
It continuously loses sync, and it seems like a loose connection because all you have to do is tap it or push down in one certain area of the board and it will straighten up. I have tried re-soldering the entire board for any loose solder connections and replaced two or three parts, but it still keeps losing the sync signal. It's not in the cable that goes to the monitor. It's definitely on the monitor board.
Thanks for any help
Thanks for any help
