People with more than one PCB in their DK style cabinet... How are you mounting them?
ChompingQuarters
Clinton Township, Michigan
DK and DK Jr. PCB's fit nicely on the slot... How are you securing the second PCB on the top of the PCB? Any photos?
I have 6 boards in my DK along with a 6 in 1 switcher.
The DK boards are easy,just use a strip of metal cut to length and a hole on each end.
The switcher is behind the Pac-Man board and under the coin box.
Here are some pics.
attachment.php
attachment.php
What games do you have in there?
DK
DK Jr
Pac-Man
I see an Atari, Dig Dug maybe? What about the others?
Here are some pics.
attachment.php
attachment.php
Wow, that's nuts! What does your control panel look like? So, you just JAMMA'd the whole thing up?
You can buy brackets that look like that too...just might have to find one with large enough holes to mount boards or buy some custom screws...
Those are just corner brackets that were in the cab when I bought it,not the original brackets.
I put a strip of metal to extend the bracket for the other pcb.
You can buy blots and nuts at Home Depot or Orchard Supply,if you have on there.
I go to Orchard for nuts and bolts because they have a better selection.
The cab was jammatized when I bought it,so I figured WTF put more games in there since I don't have room for more that 1 cab.
There is DK,DKJR,Dig-Dug,Pac-Man,Galaga and 60-1.
The galaga is mounted under the monitor and the 60-1 next to the monitor.
There is only 2 extra buttons,a sanwa 4 way joystick and a track ball on the cp.
Here is a pic of the front of the cab.
I still need to put a DK vinyl cpo in place of the generic one.
The coin door is perfect and original finish from ebay for $45.00.:D
attachment.php
attachment.php
the couple of people I know who have DK, JR and DK 3 boards all in the same cab have removed the coin box and built shelves where the boards lay horizontally with the edge connectors facing out towards the coin door. Basically you onep the coin door and move the edge connector to change between boards.
