Lescell
Pentranic CH-288
The chassis fell off of the frame and shorted out on the tube (monitor was mounted upside down in the cabinet for some reason). This popped the fuse but also shorted out the k1507 transistor on the aluminum shroud (which is probably what popped the fuse). I replaced the k1507 but it shorted out again and popped the fuse. I pulled the c4742 again (HOT) and it's not shorted but the readings make me think it's not in spec. Aside from that, any other suggestions on what to check next so I don't just start shotgunning parts?
