zerorob
Just recapped my CH-288 and as a tired newbie mistake, I kinda went gunho desoldering all the capacitors. Well the kit didn't have 4 that I removed, I was wondering if anyone else might know what went where.
C201, C202, C203, C204
These seem to be multi use points. But did have tiny caps in them, 1uf to 47uf but I'm not quite sure what came from where. In the schematic they were labeled with resistors tho, and no cap values, but the PCB does have a Cap printout on it.
Also, on the neck board, Resistors R791, R792 and R793 are burnt up pretty bad, thinking I should replace them but they have no color code on them anymore. I cant seem to find them on the monitor schematic either.
The Ian kellog kit also had a Capacitor for position R113, where my board has nothing there at all, and it is a resistor spot. Do I put this in place ?
Thanks in advance, I tried to search but didn't turn up quite what I'm looking for, Thanks in advance guys.
