Pengo Harness to Jamma adapter?
To play Pengo in a Jamma setup right? I bought one of those years ago and never even tried it since I ended up getting a 48 in 1 and it is on there. I believe I still have it, you want me to check?
Nope, I have a dedicated Pengo and want an adapter to install a 60 in 1 for a little while. But, if it doesn't exist I could probably install a jamma harness right next to the original harness and then get an adapter for my original board "just in case".
A little more work but not too bad.
Let me know what you have.
I bought it to play a Pengo board in a Jamma cab so I don't think it is what you need, but I'd be happy to check for it and if I do still have it send it to you (free), I'll never use it.
Why dont you just make one? Most adapters your going to find going to be XXX board to jamma, not the other way around. If im thinking right you could add a fingerboard and an edge connector to that adapter to make it go the other way....sound right?
It would be a rig but should work fine. Building adapters are dead bottom of my list of favorite things to do or else I would build you one.
