Pengo control panel question
shilmover
Washington
All,
Do you know if any control panels from other games (Sega or others) fit the Pengo cabinet?
I need a control panel (populated or not).
I believe Pengo is a unique cab. Not sure that sega made any other games that used the exact CP. Zaxxon super zaxxon, and congo bongo are similar but due to the different angle of the bezel they have more of a 90 degree angle to the end of them. Actually this 90 degree angle is an extra inch maybe 2 that pengo does not use. If you had a good means of cutting the metal straight I believe one of these could be modified to work. Other than this I believe they are the same. Best bet is probably to buy one off ebay. They show up from time to time.
