PCB Pads
Sometimes you can use eyelets, other times you have to use blue wire.
Alot of the boards have problems with pads lifting, but the main cause is to much heat when de-soldering.
eyelets? What are they and where can I get them? and by wires, I assume you mean create a jumper?
If the pads are delaminating you are using too much heat. Sure some boards are more prone to this than others but if you have the right equipment it wont happen.
It happens even with the best of equipment. You repair long enough, you learn to live with it. I have a roll of wirewrap next to the bench at all times. :)
