pc10 gun help
dirt
lake havasu city, Arizona
i have 2 guns for my pc10.
gun #1 when you pull the trigger the screen flashes but you cant hit anything. also there are no boxes around the targets when you fire.
gun #2when you pull the trigger the screen flashes but you cant hit anything. there are boxes around the targets.
i already searched and saw a good cleaning helped some people so i cleaned the monitor,glass on both sides, inside the barrel of the gun. nothing changed. i also noticed on gun #2 there is no light that comes out of the gun when you pull the trigger, is there suppost to be? i didn't check gun #1 for the light.
anyone have any ideas what the problem is?
no light comes out of the gun the gun recives/detcts light from the monitor
dont know about gun 1
on gun 2 it sounds like either a broken signial wire or the rotary contact mech inside the gun is not making contact
gun 1 may have a bad optic sensor
worse case just do what i did and go buy a cheap nes zapper and install the optic board from the nes zapper into one of your guns
you will need a dremel tool to do so allong with the security bit tho take appart the pc10 gun
