PC10 gun cable
darkcat1
Winston, Georgia
Hi guys I bought a mostly working gun(I'll fix it with the zapper mod) from a member here but the payphone like cable cover is broken at the base of the gun. does anyone know how to fix that? Also about half the screws are missing from the gun but I thought I'd try ace hardware
I recently did this. If I remember correctly, and we are talking about the same thing, you should be able to take the gun apart, then loosen the couple of allen screws on the metal spindle at the bottom. This will allow you to slide the metal cableing down off of the gun and off of the inner wire. Trim the metal and file it down then slide it back on.
Is that what you needed?
thanks after looking at the gun specs on the playchoice site I figured I could just make it a fraction of an inch shorter in about the way you mentioned. The only replacement for the metal tube cable I could find was a huge coil of the stuff that cost $100.(it's commonly used on payphones) The same site did have a 7ft cable all wired up but I'd have to yank the phone wires out and slide the 3 gun wires through it.
