kjoel
PC10- cant get the "reset" button to work
Hi Guys,
I have a2 x PC10 units on hand. I wired 2 of them up and all the buttons works on both except the "reset" button. I swapped 3 known good boards and it made no difference. Button are wired as follows. There are 3 leads on the small switches- 2 leads are close to one another. I wired the color wire to the middle of the switch and the ground to the end of the switch by itself opposite the 2 leads that are close to each other. I verified that the 2 wires to the board are good. I also plugged in another ground to the switch and it made no difference. I even plugged the 2 to each other and nothing. If I do this with any switch it always works. Hence the switch is not the problem. Maybe there is a dip setting for this? Not sure as 8 of the 16 dips are not labeled on the PC10 manual. I will even run a small wire if need be. Anyone know how to resolve this.....
Any ideas??
Thanks guys
Hi Guys,
Any ideas??
Thanks guys
