Pc to blast city issues
Critchy87
Donor 2019
Buckhannon, West Virginia
I hooked my old pc with a gtx1060 hdmi to vga, with pin 9 removed, directly to my ms2930 chassis switched to 31 hz and my video appears to be scrambled. I've never had adjust anything on the chassis before as far as picture goes and have hooked multiple jamma boards, mistercade, and a Naomi 2 up with out having to adjust anything but some minor tweaks on the control board under joysticks. I changed resolution to 640x480 before hooking it up. Just wanting to see if it's normal to have to adjust pots on chassis to get pc to display correctly before I touch anything or if I'm maybe doing something wrong. Using jpac for controls only. Trying to set up mame and street fighter 6
VGA (resolution, not the dsub connector) is VGA. If it works with Naomi and not your PC, something is wrong with your PC settings assuming you're using the same cable as with the Naomi.
Yea I finally got it for some reason I had to set my pc to 59hz instead of 60. Don't have a clue why. any idea why it won't work at 60?
