Pc-10 no sound
edretti
Maryland
I have a play choice-10 that has no sound. Just a buzzing noise from speakers. Everything else appears to work just fine. I just turned it on one day and it was like this. Any ideas? I am a novice at this so please be specific. Many thanks!!
points to consider:
have you ever adjusted the volume before? (it's a knob on the monitor adjustment board)
has the monitor AND audio board ever been recapped?
and most importantly
if the brown and white audio cable coming off the main board going to the monitor plugged in? :)
considering you hear things from the speaker, I'm going to assume the speaker wiring is connected and that the speaker is not blown.
one easy thing to try is with the machine off, just keep turning the volume knob back and forth. this will wipe the pot and kind of self clean it if it were dirty.
outside of these things, they're all I can think of. maybe someone else has another suggestion or two to try.
