pay to make me a adapter
rony2211
weaverville, North Carolina
hell i will pay someone to make me a 10 pin adapter for my Sencore CRT Tester and Rejuvenator CR 143, or point me to a guide i could try and make one myself thanks Ron
For a CR-23 socket I presume....
I made my own for my Sencore CR161, should be the same pinout as the 143.
Do you already have any adapters at all ? (to modify)
I modified one of my adapters using a K4600 neck socket since the adapter was already hacked up on that socket.
I have all the pinouts/color codes and whatnot if you want.
Can post pics of it or whatever you need.
ya i have 2 sets of 3 adapters and a old 10 pin neck board if you have the pinouts that would be great shoot a pm with some info thanks Ron
See if these make sense.
Note that TWO of the crt socket pins will have three wires each on them. The rest all have just one wire each.
There may be an extra yellow wire from the old socket that you cut off. I just clipped them and left them unattached.
A couple quick pics of mine.
I thought about looking for a "slimmer" socket and redoing it, but it works so good I've used it a hundred times now it seems.
This socket is one I got off a busted up K4600 neckboard.
I can grab some more detailed pics if you need them.
