TheGameFan
I just picked up a generic 19" Z-Back cab. I removed the lock bar from the front, which was mounted on a big steel plate. Under the plate, I found a 2 inch by 1 inch hole where evidently someone had tried to break into the coint box. What is the best way to repair this? I've seen a lot of use of BOndo, but this is generally for chips, not for holes.
I am thinking whatever I use doesn't need to be perfect, since I am likely going to apply balck laminate over the surface anyway.
This brings about another question, is it acceptable to apply laminate over laminate (it is currently red laminate).
