Party Zone and Shadow
spanks_4
Denham springs, Louisiana
They both arrived here at 12 last night!!!!
Couple issues:
PZ
The robots mouth doesn't move. I can hear the coil clicking and the mouth kind of jiggle, but it isn't going up/down fully like it should. Anyone know an easy way to get behind the robot to see whats up?
SHADOW:
The left diverter on Shadow is missing the knife, but also seems to be missing another part that holds it in place so it can go left to right. The entire shaft/diverter goes up/down and when it is down it won't turn left/right....Any ideas or good shots of this assembly?
The right flipper seems to get weak after a few minutes, but I have a sleeve here that I hope will work.
Shadow:
bunch of switches out: switches: 31, 51, 63, 64, and 65.
I noticed the magnent/wall switch and both right wire ramp switches weren't working and those are all the switches it says have issues when you push the service button. Lots of lights out also so going to check fuses tomorrow and see if maybe it is a fuse causing it. What bulbs are in the rings? only one bulb works out of 4.
The wall notices balls hitting it and starts multiball, but doesn't drop and magnent doesn't grab.
