I have two cabs that I am working on and one is particle board with laminate (cab1) and the other is plain particle board(cab2). Both have a little swelling along the bottom. Cab2 also has some rough edges along the bottom and also rough corners. I don't care much for the corner protectors but will use them if necessary. But what snouty the rest of the bottom edge? The cab had aluminum angle iron on it. Should I just replace it? The guy buying the game isn't a hobbyist but I want it to look nice for him.
Cab2 only has swelling and I need to figure out how to remove the swelling without removing the laminate completely. Also, provided I hav to cut the laminate off of the bottom 2-3 inches (to be able to sand the wood), should I use bondo as a filler and just paint the cab as planned? I've used grip tape as a toe kick on the front before to replace what was there and keep it the same as it was before. What could I put on the sides (if anything)?
