Paperboy yoke "sloppy" in 1 direction
telengard_t
New Hampshire
I re-did my yoke replacing the broken gears, all the springs, the anchor nut/bolts, new circular spacer, and got a new lower housing that was welded correctly. Even after replacing all of this and lubricating, the yoke does not return to center well when pulling back. Other directions are fine.
Anything else I can replace/check?
