Paperboy or Champ Sprint CPU board
djsolzs
Donor 2013, 2024
cincinnati, Ohio
Ive been looking to buy a custom atari chip and Im just not sure thats going to happen - does anyone have a Paperboy or Champ Sprint CPU pcb they can sell me??
I have an APB board set (both boards). Would that work for you?
It had an 6502 error but I replaced the 6502 and that didn't fix it.
I think the cpu board might work - would you sell just the cpu or would you need to dump both?
I have a paperboy video board I just need a corresponding cpu board.
Are the CPU's not interchangeable with rom swap and slapstick swap?
If your going for paperboy, you need a fully working board where as champ sprint does not have speech.
can you elaborate on that?
(sorry for the thread hijack)
some of the system 2 games use speech, some of them do not. so if the board has a bad speech section, use it on a game that does not use it. Pretty sure all of the games in test will test all 3 elements if it uses it or not.
Yes although I think I found a source.
I assume you need the DEC T11 CPU ?
If I could buy a working board set I would hard to come across.
I've heard some have bad speech and operators switched those over for games that didn't need the sppech. But I assume it can be fixed in any case?
