Paperboy insufficient voltage to Video Board
TheDrewster
Donor 2012
Reno, Nevada
So I just turned on my Paperboy for the first time since November and now it will not boot up. I am only getting 1.73 at the +5 on the video board. Which is the culprit, the Power Supply, Big Blue(s), or ARII? I havent checked any other voltages anywhere else.
Check the voltage outputs of the brick to the ARIII, then check the ARIII outputs, then check the output of the DC power supply. The voltage on the top board is mainly from the DC power supply. The voltage on the bottom board is mainly from the ARIII, which is fed by the brick...
