Paperboy Handlebar Removal Question
webdoc90
Donor 2012, 2025
Simpsonville, South Carolina
I'm trying to restore my Pb handlebars and started to remove all the items. I got to this point and I'm. It sure how to remove these. See photos. Any help would be much appreciated. They look like metal hollow dowels.
you have to smash/press out that roll pin. its a bitch. the manual has good info on disassembly/reassembly.
You need a pin punch and drive them out with a hammer. You can find cheap sets at harbor freight.
let it soak in pb blaster or wd40 for a while. i found a torx driver that was the same size and was able to smash them out with a hammer. then very lightly sand/clean them before putting them back in and they should go in easier.
