SOLD - PARTS Paperboy Dedicated Full Game Harness
Level99
Permanently Banned - Anon seller failed to verify
Donor 2016-2017
California
A batch of Paperboy harnesses, dedicated type which uses R/A III, are available. I'm not sure how much demand there is for these. Pictured are ten sets and only five sets are remaining. If not enough, I can get some more done in a few weeks. I have other harness orders in process right now, so those go first.
Each set includes:
1x MAIN HARNESS A043164-01
1x POWER HARNESS A043165-01
1x 5V POWER HARNESS A043166-01
1x 5V AC POWER HARNESS A043167-01
1x SWITCHER AC HARNESS A043168-01
1x VIDEO HARNESS A043169-01
1x LIGHT HARNESS A043170-01
1x CABINET CONTROL HARNESS A043176-01
1x UTILITY PANEL HARNESS A043177-01
2x LIGHT AUX HARNESS A005493-01
2x GROUND JUMPER HARNESS A037540-01 (not pictured)
1x FAN HARNESS A043171-01
1x Y-ADAPTER HARNESS A043172-01
This is a complete solution, minus power cord, coin door wiring and controller wiring. I'm offering each set @ $175 shipped. PM if you'd like one. I'll update post when/if I sell out.
More pictures
And more pictures
Do you make the little conversion harness that allows you to use paperboy controls in a chamipionship sprint wiring harness?
No, i bought one off another member here, it plugged into the controller's plug and into the plug for the wiring harness.
The only things you need obviously is the controller with harness. There is a harness that plugs into the controller directly to the cpu board. That is it! A champ sprint has the same situation, it plugs directly into the cpu. Paperboy lead from controller to cpu has 2 mta connections, champ sprint has 3 mta connections.
Then you would only need a portion of the paperboy CP harness... The portion that connects to the PCB... The reason it comes in two pieces is so you can disconnect the CP without having to open the back door to disconnect from the PCB....
To do as you want, you require this harness alone:
That'll do it. Hook up one end to the CPU board and the other end to the Paperboy handlebar controller and you're done.
Edit: This is something you can purchase direct from markrl, btw.
I have one remaining dedicated Paperboy wire harness set. If you would like this last one or some other harness, fire off a PM.
All sold. Thanks guys. If there's anymore interest in these, I can make more. I'm unlikely to stock these and instead only run small batches as requested.
I just made another short run of these. I have 5 full sets remaining. Still $175shipped per set. If you'd like one, PM me.
I'm down to two remaining Paperboy harnesses. If you're on the fence, act fast. These last two will be gone before the week is up. I won't be making anymore of these until sometime after the MCR harnesses have been completed, so it might be 2+ month wait.
I have one reproduction dedicated Paperboy harness left. After I sell out of these, I won't have anymore ready to go until sometime in September.
Alright, it looks like the last one is spoken for. So, that's it for now. If interested, PM me so I can keep an interest list handy.
