So, I have been converting a Championship Sprint to a Paperboy and I have all the parts now. The only thing that is confusing me is the control panel wiring. I was able to get a Paperboy control panel wiring harness that feeds into P106 and P102 and then leads to the large molex connector that plugs directly into the Paperboy control panel.
The only controls that work are the left and right buttons. No movement or speed up/slow down. The wiring is still attached from the gas pedals to the PCB from Championship Sprint. In test mode, there is movement on the values but it doesn't look like its affected by moving the controls. Just automatically fluctuating.
There is also a small one-wire connector that comes off the Paperboy control panel wiring harness near the large molex connector and I have no idea where it goes.
Can someone help me with this or possible post pics of their setup and where the small one-wire connector goes? Thank you for the help. I will try to post pics later today.
Torin
Torin
