The Paperboy works, but the ESB wont let me select a size?
Does the Paperboy only come in that orange color?
Grabbed PB, ESB, and I, Robot along with 6x Omron rheostats (assuming they are the same as OEM).
I got an error at the end of the order process though:
"An error occurred while processing your transaction:
unable to verify transaction using PDT. Possible problem with identity token."
Payment was verified via a PayPal receipt though so I assume it went through.
Also your site generates SSL cert errors. I assumed it is shared SSL and just proceeded, but if that is the case then for others' peace of mind you might want to look into fixing that with your store software or host.
The connection was interrupted
The connection to www.atarigames.com was interrupted while the page was loading.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
I've been getting this all day using Firefox. It happens when I try to checkout.
I am working through a proxy server, but I've never had trouble like this before. Any idea?
I am getting an error as well... not the same though. I PMed Scott with the actual error... still waiting for a response.
I just tried again and it produced the same error message.
Seems to be working now. I tried from 3 computers at two different locations, and it's working fine.
Yes, I'm bringing all of the shirts I have to CAX.
