You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
Hello lads
Was hoping that someone could clarify a few points for me with regard to burning pal/gal ic's
I've manged to track down a Chase HQ board and jumped on jammanet to source out some pal ic's namely IC 21 (Pal20L8)- now a few questions: listed as the target device is the PAL20L8 however upon reading a few posts am I correct in saying that I can use a GAL20V8?
I read that when replacing a pal you need the equivalent gal ? - is this correct or have I misunderstood somewhere along the line
Or do I have to stick with the the target device IC listed on jammanet. ( In my case replace IC 21 Pal20L8 with identical Pal20L8)
I'm also using a ttl866IIplus programmer - any help on the above as so I can get a set understanding of the exact process for now and also future reference is greatly appreciated.
