Paint code for Neo Geo red
drewster98
Michigan
Anybody here have or know of the Neo Geo "Big Red" cabinet paint code? I found one off of Neo-Geo Forums but it was old and HD doesn't carry that kind of paint anymore. The guy tried to make something equivalent and after putting on a coat it appears he failed miserably. I'm lucky I don't own a camera because I'd show you the worlds first gay Neo Geo cab. So I'm still searching for the paint code then. :)
You should just leave it pink. Its the new red. That Neo Geo have any fighting games? :p
well tore a chunk out of my neo 2 slot today and went to hd
got a paint code
i got mine in satin but its a little to shinny eggshell would be better(guy talked me into satin said eggshell would not be shinny at all dip shits ad hd lol)
i used glidden
gildden
base gl6213- satin
clrnt-----ax-----kx-----r-----v
oz-------3-------0-----8-----3
384th --144-----96---236---292
im going to paint an old beat up froger today that im converting to a multi with it so ill post back and let you know
ok looks like the color maych is a little off it seems to be a little to red
so if you are trying to touch up a cab this color may not match (its super close tho) my mom thinks its just fresh and that swhy it looks a little brighter she says its a perfect match
you decide
my neo
the new neo piaint code that was matched from that chunk i removed in my neo cab (argggg i tore a little peice and the hd guy said he needed a bigger one hence the big rip on the top of my cab )
The picture of the neo isn't as crisp so it's kind of hard to tell, but the red on the frogger looks good.
The frogger looks a bit more orange to me. They must have used a little bit too much yellow in it.
i think thats partly my flash
if you look in the neo pic above the carts you can see the flash and its orangeish
and on the frogger you can see at the bottom whre the flash does not hit its darker red
Your right, it was the flash. That doesn't look bad at all.
