Pacmania cab wiring
dexx30
Donor 2012
Veenendaal, Utrecht, Netherlands
i have almost fixed my pacmania cab, there is only one thing..
where do i put these 3 wires??
http://members.ziggo.nl/jpveenstra/Arcade/Pacmania/DSC02244.JPG (warning HUGE pic)
it's about the yellow, white, and black cable.
Yellow spits out a 210/220 AC volt.
white cable does nothing (Ground?)
Black cable is like the white one..
also, the machine is now working.. but i have the feeling i'm forgetting something :D
EDIT: the wiring diagram is the same as the USA cab.. so if someone can shoot a photo of the PSU wiring ;)
Looking at the schematics it goes to the flourescent light fixture. Dont see 220v for it though.
Here is a shot of mine. The yellow wire goes into the molex plug and heads up somewhere in the top of the cab, assume its the marquee light power. The white wire goes on that terminal block on the lug the black wire is on in your picture.
@kjoel, that true.. that's my last step, getting a 15w 44cm tube (philips/osram) is not a problem :)
@Riptor thanks, it looks different in your cab :) i cut the molex connector for the 230 volt because it broke off :( i soldered it back to the wires for main power :)
i figured something out, if i'm correct.... the white and yellow wire are not used in this cab.. because it's WORKING!! :D
