learpilot2
I just got a pacman that has a hum bar (flag effect) in the maze on the screen. I noticed that I have a 6"x4" circuit board with a lot of resistors plugged in between the main pacman cpu pcb and the main edge connector. It looks factory. Is this the useless filter that everyone refers too? Do I just pull it out, and attach the harness to the main pcb? Is that safe for the machine? Will that alone fix the picture wave?
I also bought a new fuse holder and a molex edge connector to replace the old original one. This is the first I have made a new connector. I ordered from Bob Roberts, and it did not come with instructions. Do you just clip the old wires off one by one and transplant them into the new molex connector? Do you feed the wire through, attach a prong, crimp it, and then pull backwards into the connector, or do you solder each one to the wires. I bought a crimper, so I assume you don't solder.
Thanks for the help.
