taulpaul
I'm trying to get power going on a pacman that a switcher inside. Switcher gone, and back to original harnesses. I want to bypass the interlock. I have one brown wire coming up to the interlock from the line filter, and another brown wire running up to the interlock that is not connected (need to find out where this goes). The blue wires look fine. I know you typically tie the blues and browns to bypass, but I'm missing some connections here, and I need some advice how to correctly hook this up. Attached is a simplified drawing. I'd like to be able to use the power switch, and bypass the interlock in this drawing.
