FS Parts: pacman pcb plays galaxian
partygt
California
i have a galaxian pcb that came up working in a pacman cab? i got this in a lot of pcbs plugged into friends
pacman cab to test and galaxian came up working 75.00 shipped
That is most certainly a dedicated Galaxian board. It works in a Pacman cabinet because it shares the same pin out as PacMan.
Notice the absence of the two daughter cards and also the long ROM card. That's 100% Galaxian! :D
Does it play Galaxian or Pacman ?
There was a hack for Galaxian boards that played Pacman.
JD
Cant be to much fun in a pac cab.. No way to fire..
I think if you press up on the joystick it will fire. If you pull down it will blow a fuse...something like that if I remember correctly. So yeah you basically have the same pinout except the controls and maybe the speakers. Its been a while since I looked it up. Yes that is a dedicated galaxian pcb.
