PacMan coin slot not working right
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
Putting a quarter in the slot may or may not work.
PCB or bad coin switch?
The pcb is a 48-1
It would also be worth checking for a loose wire somewhere, either on the switch end or near the edge connector. You could also have a molex pin that is corroded/bent on your edge connector and making intermittent contact.
Jump the switch wires and if it works every time they touch, the issue most likely is the switch.
