Pacman coin door light
chrisj1970
Arizona
Was there a small light on the coin door to illuminate the .25 cent sign on the pacman upright game?
No, Pacman uprights did not have coin door lights. The cocktail version did though.
Ms. Pacman uprights DID have 12 volt coin door lights (#194).
You can run power up from the power brick and install your own coin door lights. If you have a crimper & pins, you can run the power right through the coin door molex, nice and clean.
Even though it's not 'original', I added coin door lights to my Pac-Man because I like the way they look. The #10 bayonet lamp holders from Bob Roberts work perfectly: http://www.therealbobroberts.net/lamp_holders.gif. Since I'm running a switcher, I used 6V 44/47 lamps wired up to the -5V terminal of the supply (through a fuse) and through an unused pin in the coin door connector.
