Pacman cabinet help
jsissel
Donor 2017
Missouri
Let's try again. Doing this on my tiny phone with big fingers.
I've been looking at pictures but they really don't give enough detail for me to build a correct replica. How does a Pacman rear panel attach to the cabinet? It looks like it fits in a rabbit all the way around so it is flush. I believe there is a small board (1/2" thick) attached to the bottom panel to keep the back from being pushed in. I also believe there are 2 screws that fit into blocks midway up the sides along with some sort of lock at the top. Any details would be very helpful and appreciated.
Mostly the bottom. I'll tackle the top later. I have a PS and wiring harness coming soon that I can measure and there are decent pic of the inside around.
It's a tongue and groove on the bottom. Something I hadn't considered! Thanks
Here's a photo with dimensions I made earlier for the back Pac door in the event this helps in any way:
attachment.php
I had found this earlier and it is perfect. It is details like this that are often so hard to find. Thanks everyone. Hope to get the power supply and wiring harness tomorrow and start working on the pcb.
