Pace Soldering Question
Zud
Madelia, Minnesota
Does anyone own a PPS-101? If so do you like it? I used a PPS-400 at the local college when I took a class there. This unit looks like that one except maybe an earlier model. I cannot seem to find a manual or info online about this unit.
That's an ANCIENT one that uses higher voltage irons. I wouldn't buy it.
Get one with Sensa-tip irons. They use the round multi-pin plugs and not a standard 110v connector like the PPS-101 does.
Thanks for the tip, no pun intended. :p
