I converted a Pac Plus back to Pac in order to add a Widel 96-in-1 kit. At the same time I swapped out the 2114's for new RAM. During the process I manage to screw up one leg of one of the RAM and that is what was causing the menu to read 96-IL-1 and MS. PAC MAL. Once I fixed the leg, all was good... until I actually got in to a game.
When playing a game I get the following symptoms (youtube link):
http://www.youtube.com/watch?v=twAAGCAkLA8
Now, this is a non-capped monitor I pulled from the Pole Position (where it was working fine)... so I thought at first it may be a monitor chassis issue... until I turned up the sound and could hear the sound distortion as well. That tells me it's not likely a chassis issue... right?
Any suggestion as to where to look... where to start? FYI: I tried with the filter board off and on, and believe it or not, with the filter ON it seems better... (this video is with it off).
