Here is a few shots of my 4n1.
How do I upgrade it to the new 3.3 version from http://arcade.souzaonline.com/4n1hack_3.htm
I've never changed the names. All I do is alter the arcade.souzaonline.com text manually in a hex editor.
I did a file comparison on the 2 files and they are identical. You can always try burning it just in case. Did you edit the text? If so, I think you want to make sure it's the exact same length. I padded my text with spaces before and after to keep the string the same length. BTW, to get a space, use the "@" character. It doesn't use standard ASCII values for non alphanumeric characters.
