Will a Ms Pac CP fit on a Pac cab?
The difference is pac had a piece of wood on the bottom and mspac was just metal. Yes you can make it work and its not too hard to do.
Just move those brackets up and it should work fine. The plywood is 3/4" so you should move your brackets up 3/4"
You don't want to add the wood unless you are willing to put wood screw holes in your control panel and have to route out the joystick mount recess. It'd be easier to just get a Pac CP off the bay or reposition the latches as mentioned.
