superbert1971
i had a power supply switcher go bad on my in my pacman. at some point it was added. I bought a used one on ebay where he sells alot of them so i was ok with a used on. Now when i hook it up the same way i get a humming noise from the unit and the digital 5.0 reading goes blank. Is the unit bad? its not till i hook the wires that are soldered to the main board that it happens.....just the two A/C wires work fine its like theres a issue with power coming out. Im at a loose....i just figured id swap and be playing by now....any ideas?
